Tractor Gauges
moderatmixed
27
Woodstock, Ontario, Canada
I want to install a set of gauges onto my B6100. The intention is to put an oil pressure/water temp/voltage/fuel qty and Tachometer.
Anybody have any suggestions where it would be best to put the temp sender for the water temp, and what temp range is considered normal? Too where would be best to attach the sender for the tach.
I'm thinking about going digital for space considerations, and the possibility of adding a digital hour meter and hydraulic pressure.
Any thoughts, (other than cost)
Cheers
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
I just added a water temp guage to mine. I drilled a hole in the side/top of the radiator and soldered the fitting in it. Mite not be a good idea if you can't solder.
On the oil pressure, I use a tee fitting so I can keep the idiot light. Most of the fittings on the Kubota are metric, so be careful.
