Tractor for woods and trail use?
WindyHill6561
Very old Kubota
Oct 18, 2024
Finger Lakes, NY
Hello to all. New to the forum. I am a one tractor owner. I have an OLD Kubota L295DT that is at least 40+ years old. It was gifted to me about 15yrs ago. It is a bit tired and underpowered for my needs. Looking for a used diesel Kubota that predates emissions stuff if possible. I will need quick disconnect front bucket w/ 3rd function and a rear remote. I want to use this for road grading, bush hogging, possible DIY logging. I have 73 acres mostly wooded with some steep hills. Any advice or thoughts please to get me started in right direction. If this in wrong location please feel free to move. Thanks in advance
nbryan
Jan 3, 2019
1,436
950
Hadashville, Manitoba, Canada
Other than not needing 3rd function or rear remote here, my kit does really well with bush/forest work.
fruitcakesa
M4 071
Oct 26, 2010
892
308
Cavendish Vermont
I own 50 acres of mostly woodland that I log on a regular basis and also plow my long driveway as well as my neighbors. My first tractor was an L4630 and it served me well but I decided that the scale of the work that I planned on doing for years to come was large enough that it justified a bigger tractor. I now have an M6040 and am glad I moved up to a M series machine.
Only one remote but for my uses it’s sufficient. Also I have cabbed tractors for a lot of reasons and accept the limitations it has when working in the woods.
As has been said many times on this forum
“Always go bigger”
chris_the_wrench
L3902
Oct 31, 2023
Chinook Pass
“Always go bigger”
Steep hills and big tractors? Can you maneuver straight up and down those steep hills, or will you be side hilling? My property is STEEP and requires alot of side hilling, there is NO way I’d want a cab with that extra weight up high.
Really think about where and how you will be dragging logs or whatever jobs you need to do?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,964
2,462
WestTn/NoMs
50 hp is the sweet spot for a utility tractor to me. An MX5000 would be pre-DPF in that range. Some of the older M's, such as the M4900, were smaller than the current M's.
BAP
Dec 31, 2012
3,200
1,316
If your hills are really steep and you are going to be doing a lot of logging, buy yourself an older, smaller bulldozer with a winch. They will go almost anywhere safely and you can grade and make roads with them. We had a JD450 dozer with winch and logging arch. It was great in the woods. Pull like crazy, very maneuverable, fit in tight places and very safe in rugged terrain. Then have a small tractor to do your bush hogging.
Reactions: 6 users
BX23-S,57 A-C D-14,
6,323
'side hilling' may be last thing you'll ever do.
Have a steep hill to access other areas? You've got a tractor.... carve it down to a GENTLE grade.
Agree with BAP, get a 'trim' dozer (small). Use it to grade the land for SAFE access, then you can resell if you want to.
Burrdog
l3650, L5450, M59, Dresser 518, IH 8400 SA dump, FrtshakeFL120, Trail king TK24
Great question you have posted but it could read "best two Kubota Tractors to own" !
These things are like boats similar but have differing missions. With that said get the biggest you can fit under cover and transport and afford. The largest "L" being the minimum. I maintain heavily wooded acreage in a low impact principle with an accessorized L5450. My forest portals are modest 7' to 8' in width were as they would need to be 12 feet with the smallest skidder like JD440. Quick attach front with aux Hyd. for brush grapple or log grapple, 3-pt rear with 3-spool Hyd. for box scraper, log grapple tongs & 10,000lb winch. My wife calls this my "Swiss Army Knife" machine. I have two "Implemax" hydraulic grapples and the thing does look funny with one on each end but what versatility!
The thing to do is just jump in and learn on the fly check out what others are using and you will figure how to maximize your efforts.
Cheers and thanks to all for the great tractor site
Burrdog
Grandad4
Apr 5, 2016
445
195
Greensboro, NC
If a dozer or skidder is beyond reach for your needs or resources, check out a pto-driven logging winch. Allows you to keep the tractor on safe terrain while gathering logs and is easier, quicker and safer than dragging them from the drawbar. Not cheap, but you can get pretty much what you paid for it when it's time to sell it.
