B 26/20... 2013 very low time. Now my tale of woe:
Today, after hearing a weather forecast for snow, I removed the FEL and hung the plow. The plow wouldn't move at all... After checking the hose hook-ups and finding no problems in that area. I moved the control lever thru all of it's positions.. Many times, and at high and low RPMS.. the blade would move a bit... but intermittently... and not thru it's full range. The blade sometimes moved the wrong way; i.e. up and down and or L&R when it should have moved in the proper directions. Never saw a full range of movement. (the tractor is sitting outdoors right now) All other hydraulics are working perfectly...
Other times when swapping loader for plow I have seen signs of a bit of air in the system.... but it quickly set itself to rights.
Steve.
Steve.
