Torque Settings for Hydraulic Pipe
jp2code
L4400
Jun 9, 2017
41
LONGVIEW, TX
www.jp2code.net
Recently a stick or stump bent the J-pipe on my Kubota L4400 (#170 in the image below)
I have a new one ordered. The bolt (#180 in the image) was so tight that I had to push with my foot on my 18-inch wrench.
Does anyone know what it should be torqued to when I reassemble this?
BigG
Sep 14, 2018
1,953
774
West Central,FL
Wondering if it was put in with "lock tight". Have you looked at a workshop manual?
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
219
47
Dickson, TN
Well, the description for #180 says 'joint' so not much help there. Are the two #190's brass washers? Looking at the bolt in the diagram and what it is doing it looks like a hollow bolt so the fluid can flow through. If this is correct it should not take a ton of torque but could have had Locktite on the threads. You may be able to see signs of old thread locker on the bolt. If you have a WSM for your machine it may tell you the torque spec.
Hopefully Dave will chime in.
jp2code
L4400
Jun 9, 2017
41
LONGVIEW, TX
www.jp2code.net
I do not have a WSM. That's why I was hoping that someone could give me the torque settings.
Yes, those are 2 brass crush washers and the bolt is hollow like a break line bolt. The bolt was clean of any Loctite residue.
So, nowhere to get a PDF of the Kubota WSMs then?
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
267
69
Southern IL
If not Locktite, possibly paint from factory holding it fast if this was first time removed.
Just a guess...maybe 30-40 lb range??
3,314
Did you post the same question on TBN?
I thought I gave my uneducated opinion somewhere. Anyway, do not over think this. It is a simple banlo fitting. Tighten it up by hand and you should be fine. Best to have new number 190 washers, but originals will probably work the second time.
jp2code
L4400
Jun 9, 2017
41
LONGVIEW, TX
www.jp2code.net
I did. I don't come here asking questions often, so I don't really know which board is better.
3,314
By the way, I think you said a gorilla tightened the original, so you should not have to worry about over tightening, unless you too are a gorilla...:)
