bbxlr8
I have been doing very well up until this last Sunday evening - I have been putting in some long hours digging & moving soil/rock to level the area next to the house and add to the bank in front (posted some pic in another thread).
Well, my stupidity caught up with me again as a strong line of thunderstorms was approaching. Previously, I had to patch soon after I got the tractor, by running over an old chicken run and put three nails through the new front R14.
This time, I had a full bucket and was pivoting backwards around/through a swail and drainage run that I roughed in ( 8-10" deep by 4 feet wide) and the force pealed the other good front tire off the rim.
Dumb move #1 - While I have been great about frequent greasing and checking the oil, I had not checked the tires since my 50-hour service and am now at 130h
Dumb move #2 - I was at an angled front to back & side to side and at that moment thought " No problem, I'll just pull forward 6 feet to get level". The storm is coming, it looks like good dirt there...
WRONG! I bent up the rim badly in three spots. It was about 3" in on three spots on the outer but the inner ring was still round. DUH Rocks in the ground & weight of full bucket - Oh sh#%!
Dumb move #3 - I grabbed a sledge and worked it back into rough shape by putting dents at 6 o'clock while still mounted on the tractor. I then pulled the rim and got it close with my smaller BFH and body dollies. I then drug out my manual tire changer. At this point, I thought I had a >50% chance of it sealing but did not want to mess with it again. Luckily, I had the tube that I ordered during my previous fiasco when I ended up having a commercial truck place patch it. Get the tube on, inner bead on, and realize this is going to be a fight with the stiffness of the plies and thickness of the tire.
Oh yea, it's directional... So even with the fat raindrops starting to drop, I go out to check the tractor because I do NOT want to do it twice. Look at the one on the tractor and go '"yea - I'm good " and finish up the fight and air it up. Take it over in the pouring rain, and I'm too stupid for my own good! In my rush and I have it on backward - i.e. matching the side I looked at.
Lessons learned:
It looks stupid, was meant to pull the other way, but is functional and doesn't leak.
Options are to:
Any advice or thoughts from the collective? I know some would say foam it & I might get there down the road but I like the pneumatic OE part for now.
Thanks
Lessons learned:
- Check your tire pressures - especially when doing heavy loader work
- Don't move it on an empty rim - or at least dump the load!
- Take your time to get it right or you will do it again.
Options are to:
- Flip it manually (pain in the tail, but do-able)
- Pay to pop off and remount (seems likely that a shop would prob pinch the tube and I would find out later).
- Leave it
Thanks
