Found the noise I was hearing was from a loose hub. I removed the wheel,and hub and wedges and cleaned everything. Now my problem. Both wedges are notched...I assume one is so the bolt head wont turn when trying to loosen the nut. The problem is...BOTH are notched...so when you try to tighten the nut...all the load is on the edges of the lockwasher.
And does anyone know the torque spec on this bolt?
