Throttle wont engage
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
202
144
Villa Rica, GA
I have a weird problem. I can't get the throttle to go above idle in my BX1880. I start it and pull throttle down and it springs back to idle. Like there is no resistance in the cable to keep it where I want it. It was fine yesterday when I used it. I took the loader off to mow, but don't see how that could have affected the throttle.
Any ideas?
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
202
144
Villa Rica, GA
Figured it out. The nut that secures the throttle arm came off. Put it back and made sure the jamb nut was tight and all is right with the world.
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
304
40
Thetford, VT
That’s pretty common. I might suggest getting a nylon lock nut or you’ll surely play this game again.
I had the same issue when I got my 1860 last year, and the nylon lock nut solved the problem.
