tg1860 deck not engaging
jwcocker
Old Chatham NY
I have a tg1860 and the mower deck will not engage. If I pull the button to engage the deck , nothing happens , but I still have to push the reverse awareness button to go backwards. The switch seems fine nothing loose or visibly worn.
okellyh
L3130 TG1860
Oct 28, 2013
12
Whitehouse, TX
New owner of an older TG1860 , 1000+ hours
I have the same problem.
It mowed fine for about an hour when I first tried it. I stopped it for a few minutes while I got a cup of coffee and when I when to mow again, no PTO.
Did you find a solution?
okellyh
L3130 TG1860
Oct 28, 2013
12
Whitehouse, TX
The three fuses up top are good.
I can get the clutch to make a little noise if I put 12V on it directly with test probes. The test probes probably aren't feeding enough amp to make the clutch contact fully.
I need help finding all the other fuses listed on Messicks parts list for the TG1860. Supposedly there's a 3amp fuse somewhere.
