switching front tires side to side for more offset
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
i've noticed the offset of the front rims. i'm considering swapping them side to side to give the B a wider stance.
maybe do the same in the rear, for more stability.
what are the pro's and cons, of doing this.???
all comments / suggestions welcome....
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
Kenny is correct, either swap the rears or add spacers. I did spacers first then filled the tires, now I feel safe at the lake and don't get the pucker when mowing the hills.
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
i was thinking a wider stance would give me a bit more stability when plowing and other operations that put me at a angle.
i have the tires loaded already.
bucktail
Jun 13, 2016
1,255
190
MN
Moving the rears out increases stability because the rear axle is solid to the frame. Since the track is wider, it takes more force to tip the tractor. The front axle pivots WRT the frame, so increasing the track width does nothing to increase the force required to tip the tractor.
