SVL 95-2s no start
bsamot69
M9000, m9540, m6060, L4400, SVL 97-2
Jul 31, 2018
152
Grapeland, Texas
2016 SVL 95-2s skid steer cranks but no start. Was running then quit. We changed fuel filter, drained old fuel and refilled with k own good diesel. We've purged the air procedure and all we are getting is crank, start for 4-5 seconds then it quits. This is an improvement, however, it just doesn't keep running. Any suggestions to help us get this thing started.? It is the 3.8 engine. Any other info I can provide
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
I see you've been through the fuel system. Check the air filter. Since you've bled the fuel system I hope that means you got good fuel flow at the end of the line.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Air filters are clean, fuel flow filled up the separator bowl and filter. Fuel comes out of fitting on top of fuel filter mount. The DEF pump is pumping...where else should I check? Is it possible to bleed air at the injectors or pump?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
The manual should tell you the proper bleed points for fuel. I have three on my old Mitsubishi. The last one is the kind of manifold which feeds the injectors. If I have air there the tractor won't run.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Found that this machine has an error code of 9214, excessive then cycled or something like that. Is this a code that would prevent starting. I've worked in automotive repair industry but not with diesels or tractors. I'm seeing the computer management is more restrictive.
whitetiger
Nov 20, 2011
3,321
1,743
Kansas City, KS
Fault code E;9214= Regeneration too frequent. Your dealer will need to connect their Diagmaster program to it. Anything else is just guessing.
