Summit Hydraulics 3 spool rear remote installation on LX2610HSDC cab tractor.
billskeen66
Kubota LX2610HSDC
May 21, 2022
14
Dallas, TX
Does anyone know the thread type (SAE, BSPP, other) and size for the Power Beyond port banjo bolt on the LX2610HSDC? It appears to be a different size than previous engines, like on the B2601 shown in "MJA doing stuff"
YouTube videos. It measures 18.8MM/.740" O.D. and is a straight or parallel thread, TPI 1.5, approximately.
I've worked through most of the other issues, like mounting to the cab. This is the last obstacle.
TIA
billskeen66
Kubota LX2610HSDC
May 21, 2022
14
Dallas, TX
TIA
It is a 6801-06-08 Male JIC to Male BOSS ORB 90degree for a Kubota LX2610HSDC, which I believe is the same for several other models.
turns out I thought I had a 3/8" to 1/2" 90 but it was actually a 3/8" to 3/8".
The Summit Hydraulic kit is installed on the back of the tractor and operates the flail mower hydraulics nicely.
4,856
TIA
1.5 TPI? You might want to rethink that.
How confident are you of the .740 measurement and is it across the threads? That major diameter does not match anythjng I am familiar with.
Its very close to SAE-08 (3/4-16) but SAE banjo bolts are not common and I would not expect Kubota would be using SAE anything.
Its not even remotely close to any BSP thread but could possibly be 19mm metric. Again a non-standard banjo size but OEMs do non-standard things. What sort of pipe was the bolt used with?
billskeen66
Kubota LX2610HSDC
May 21, 2022
14
Dallas, TX
Hi Dan,
My head was inserted into a place void of solar emissions. :)
This was the correct part:
90 Degree Elbow, 3/8" JIC Male x SAE/ORB #10 Male
Summit has them. As well as Stuart Hose & Pipe, Amazon, and others.
Still learning all the different types of fittings, adapters, and couplings.
Thanks,
Bill
4,856
Hi Dan,
Thanks,
Bill
I am totally confused. Are you saying that fitting fits the factory power beyond port on the tractor or the power beyond ports in the Summit valve? SAE-10 is a 7/8-14 UNF thread.
