SSQA LOOSE
kcs
Kubota B2650
Jan 9, 2021
148
The SSQA is loose on my B2650. Is there any way to tighten it up? I’ve looked at it and I done see any way. But I could have missed something. Thanks
4,051
What do you mean by loose ? A little more detail might help
kcs
Kubota B2650
Jan 9, 2021
148
I can shake it and it is hard to get some attachments connected and when I have attachments on it it will rattling. I’ve had the tractor for 3 years and never had this problem.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Is there sand or other debris preventing your pins from going down into the bucket or pallet forks (or whatever) all the way? Does it appear bent? (a carpenters level may help)
Is it missing bolts, pins?
Cracked welds?
(details, it's all in the details!)
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
Have you ever greased the retainer pins and are they engaging all the way, do handles go down all the way and do they go over center ?
kcs
Kubota B2650
Jan 9, 2021
148
Yes I heard everything regularly. I’m sorry I put the wrong details out it is the SSQA itself that is loose on the loader arms
Mountainhill
l2501 (l3800 2013/22), Box Blade, post hole digger, Leon's rear blade
Apr 3, 2017
67
54
Nova Scotia, Canada
Had similar issues with my old l3800/LA524, wear and tear will cause the rattle and sometimes hydraulic cylinders , from side to side, get out of alignment, which can cause difficulties engaging the SSQA.
The rattle, new pins may help, the cylinders, take some measurements, side to side?
