Speed control pedal adjustment
Thurmon73
B7510 HST with various implements
Jun 10, 2012
Berwick, Maine
Hello all, new to the board...Thanks in advance. I have a B7510 HST and the Speed control pedal seems to have some play. It is to the point where I can not get off the tractor while running or it will stall out. I have narrowed everything down and it seems to be because the speed control pedal falls forward on its own after I come to a stop. Then I can often not get it started because the pedal does not rest in just the right position.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Sounds like something is missing or broken. The pedal on my machine has a torsion spring on the pedal for positive return. Check the parts manual and see if you can identify the problem. These guys will email you the parts manual for free.
