Skid Steer Help
In Utopia
L175 FEL
Apr 21, 2013
648
173
Utopia,Tx/Pasadena,TX
This is a post from a guy on another forum I'm on.
Anyone have any ideas?
I recently picked up a Kubota SVL95-2S with high flow hydraulics and I'm having trouble understanding the hydraulic flow adjustment. The max flow for the machine is 40 GPM however, when I go into the settings I can only adjust IR up to 14 and IL up to 9 and I don't know how that translates into actual flow.
So, as an example, I have a brush cutter that has fittings for the standard flow ports and supports a max flow of 20 GPM. What do I set the machine to? Is each increment in IR equal to about 2.9 (40/14)? In which case, a setting of 7 would be about right? If so, what about IL? Is it the same or is each increment there roughly 4.4 GPM (40/9), so it should be set to 5?
I've read the manual and it doesn't address this at all. The machine is great, the documentation just sucks.
I appreciate any help anyone can offer.
Marion.
Skid steer
Jul 11, 2020
SC
Did anyone help this person I’m having the same problem no where shows how to set for 32 high flow or 40 gem high flow I can set at14 and 9 is the max I’ve found
Pineyweeds
M5-111 Tractor, SVL 97-2 CTL, ZD-1211 Zero Turn Mower
May 29, 2024
East Texas
Did either of you ever get any help on this? I’m curious too.
