shuttle shift hydraulics
J Barnes
Kubota, New Holland, Ford and CNH tractors
Mar 8, 2026
Lawrenceville Pa
got a m105s just replaced the synchronizers in the transmission, put tractor back together and would not move. did a pressure check pump ok, around three hundred going to shuttle valve on top of transmission removed spring and small screen still not enough pressure when checking two ports top front of shuttle valve. any suggestions? about ready to remove valve and put on bench and tear apart.
