Shout Out to Boda products
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
I have a BX2380 I bought two years ago. Last year I noticed my tie rod end boots where ripped. So I ordered the Boda Products kit to replace them. Shortly there after a tree fell on my garage, and well my focused changed from fixing the tractor to fixing my house. The other day I was using the tractor and noticed the tie rod end boots where still ripped. I looked around and found the box with the new boots in it and figured it was a good day to install them. I got the first one done and noticed some where along the line I had lost the little E clip to hold the inner boot on. I E-mailed them on a Sunday thinking I will hear from them on Monday or Tuesday about what size it was. They E-mailed me back on Sunday with the size.
I got it this morning and installed the second set without issue. That is Great Customer Service.
The new boots are a lot heaver and seem to work better. Time will tell.
Mike
3,442
Nice post… but “Boda” …doesn’t tell us WHO provided the great customer service. There are more than just a few Kubota dealerships.
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
See I learned something today already.
Is the URL.
3,442
Thanks, OC… never knew of them. (not owning a BX)…. I like their website and products (except those $60 “Small footprint rear lights”…. The same (almost) red/amber rear lights item is available from TSC for less than $8.
B737
LX3310
Jun 9, 2019
2,022
2,204
Mlarv, when you posted I went to their website to check them out. I saw they had a tool box mount. I have wanted to get my tool box off the thin rear cross member, and eventually delete the cross piece all together. Mine is in bad shape, I cut it to allow clearance for the top link.
I saw the bota tool box mount, looks nice and clean, but faced the wrong way for me. I ordered one, cut it, and welded it perpendicular to itself. It's a really stout 1/4" hunk of metal. I am going to buy another one, mount it to the other side and attach my SMV sign, and aux switch panel to it.
it comes like this: just a big fat piece of flat steel
cut and welded using my 2nd grader hax welder skillz
Paint and mounted it up
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
Mlarv, when you posted I went to their website to check them out. I saw they had a tool box mount. I have wanted to get my tool box off the rear thin cross member, and eventually delete the cross piece all together. Mine is in bad shape, I cut it to allow clearance for the top link.
Nice you made it to second grade welding, a lot further then I got.
I welded a deck wheel on a neighbors BX1880, lets say it is still stuck on there after three weeks. I also welded my Cub RZT after hitting a very large and heavy rock. It is about 1st grade work.
I like the looks of the tool holders. I might have to look at one of them now.
