Seepage under front axel
JayAndrew
BX2680 Loader and snow blower
Feb 2, 2019
15
Woodstock, NB, Canada
Hi,
I just ran my hand under the front axel of my bx2680 (20 hrs) and noticed a little seepage of oil on my hand. No puddle on the garage floor and the dip stick is showing about 1/2.
Is this normal or should I have it checked out?
Thanks
SidecarFlip
Banned
558
My comment is, it should be full because there isn't that much lubricant in there to begin with.
bradmond
BX25D
Mar 14, 2015
46
SeaTac, Wa
My BX25 was doing that at both sides where it pivots for turning. I took it apart and cleaned everything up and switched from the factory hydraulic oil to gear oil. No signs of leaks.
Sent from my SM-G950U using Tapatalk
Muzzy
B2650HSDC
Feb 13, 2019
274
WNY
Top off with Fluid, if it continues to leak get it checked out under warranty.
I would not rush down immediately, but when convenient or if some other service is required.
SidecarFlip
Banned
558
While not related directly, I pulled the UDT on front axles on both my M's at the first service and replaced it with 80-90 GL5 Gear oil. The 80-90 provides better shock load protection, something I need as I farm with mine.
