Scoop bucket
4,908
I just found a Farm Force Scoop bucket on an IH 234,,
Would it fit my BX 2360 and has anyone ever heard of Farm Force? I havent called the guy cause i wanted to find out about it first and see if its worth a hundred bucks
Jimmysal
B1750HST, RC60 MMM, LA300 FEL, TSC 48" BoxBlade, PTO Dbar chains tongs old Stihl
Aug 26, 2010
24
Vermont
I think Farm Force is made by Tarter Gate. Do you mean this?
An IH 234 has 18 engine/15.2PTO HP. Your BX 2360 is rated at 23 engine. If the IH has no problem driving around with the loaded weight, I don't think you will. Both tractors have a CAT. 1 3PT hitch, so you're good to go there.
Kubota says your 3pt is rated for a 670lb. lift capacity 24" behind the pin. That scoop weighs 255lb. That means you should be able to lift 425lb. of material with it. Naturally you're gonna want a FEL or weights on the front of your rig to balance this. It wouldn't hurt to increase your track width on the rear axle either.
If I had the need, I'd put one on my B1750.
4,908
Ya know it's a good thing I am such a gentel and kind person,, I call the guy and said I would take it and be there with CASH in hand,, drove almost 3 hours got there only to find out that the SOB sold it the night before, and all the jagoff could say was oh yeah I forgot to tell you that
Jimmysal
Aug 26, 2010
24
Vermont
Sucks man, I've had people burn me on craigslist many times like that. I'm pretty sure they sell the model I linked above at Tractor Supply. Good luck!
