Running a SA10 post hole auger off rear remotes.
Kubotablacksmith
Kubota B2601
Jan 17, 2022
Prince Edward Island
I have a B2601 and alot of fencing to do for an rotational grazing plan.
Obviously a third function is ideal but is it possible with hose extensions to run a hydraulic auger off the rear remote. Thanks
MtnViewRanch
917
382
Lakeside Ca.
Just be sure that you have enough hydraulic GPM to run the auger efficiently. The std 1/4" rear remotes for that tractor are only rated at a 3 GPM flow.
It looks like Land Pride figures it works fine. (y)
7,473
No real difference than a third function.
WSM says rated flow of implement pump is 5.2 GPM. @1900 PSI. Compare that to the hydraulic requirements of the PHD.
