R Redstrider New member Equipment RTVX1100C Sep 17, 2022 2 0 1 Golden, CO Sep 17, 2022 #1 What is the location of the 10 amp auxilary female bullet connector
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14, Apr 2, 2019 13,093 5,770 113 Greensville,Ontario,Canada Sep 17, 2022 #2 if it's a 'standard' Kubota procedure, look for some blue electrical tape on the wiring harness.
whitetiger Moderator Staff member Equipment Kubota tech..BX2370, RCK60, B7100HST, RTV900 w plow, Ford 1100 FWA Nov 20, 2011 3,245 1,674 113 Kansas City, KS Sep 18, 2022 #3 Redstrider said: What is the location of the 10 amp auxilary female bullet connector Click to expand... It is located near the brake master cylinder, marked with blue tape.
R Redstrider New member Equipment RTVX1100C Sep 17, 2022 2 0 1 Golden, CO Sep 18, 2022 #4 whitetiger said: It is located near the brake master cylinder, marked with blue tape. Click to expand... Thank you, it is the correct type of connection. The black (male) wire is ground but the green with yellow stripe (female) wire is not energized when the ignition switch is turned on. Do you have any suggestions?
