rtv900 won't start electrical issue?
Roots and Wings
rtv900, L3000
Apr 16, 2016
Monroe, Maine
Hey there
I have a rtv900 that is having some starting issues. When I turn the ignition the dash lights come on, turning further the glow plug lamp comes on, then turning further kills everything. No dash lights, no power at all. I then can manually raise the bed a little bit and slam it down which then resets the power but it all dies again when I try to start. Seems like some clicking coming from what I think is the engine stop solenoid. Not sure if this would kill power. Any thoughts or suggestions would be greatly appreciated. Thanks.
7,832
Check your battery cables first ;) you can have a bad connection under the insulation.
Have the battery load tested as well.
Could have a bad/ corroded connection in a quick connect in the wiring harness.
Check for loose connections and pinched wires as well. Especially since you can slam the bed down and your getting juice again.
Roots and Wings
rtv900, L3000
Apr 16, 2016
Monroe, Maine
Thanks Daren
Messed with the battery cables and a few others and somehow got it running. I really have no idea what I did though. Hopefully it doesn't happen again.
