RTV1100 Repair Manual
AgEngr#1
M9000, MX5400, RTV1100
Jan 4, 2023
SE Washington
I hope someone knows how to find the correct Service Manual? I have an RTV1100 I just bought used and want to get the WSM part number to purchase the manual? Can someone look up what my machine year is that has SN 39111, Engine Type D1105 Serial No 1DE6288? I need to do service and some repairs the previous owner did not fix.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
472
268
Randolph county N.C.
Do the door windows roll up and down or slide? My WSM is Dated 2013 and appears to show roll up windows. I ordered my WSM as a PDF download off Ebay.
FWIW, When I purchased my used machine I took it to the dealer for service do to not knowing service history. They did three recall items at no cost to me. They were all safety related.
zfish65
None, Kubota Parts Specialist
Dec 27, 2022
Fleetwood
Appears that you have a 2013 RTV.
9Y111-09482 that should be your part number for the workshop manual.
AgEngr#1
Jan 4, 2023
SE Washington
The windows on the doors slide. By the way I took my utility RTV1100 to my nearest dealer and they had just got in some new orders to build machines so couldn't get at it yet. Thank you for your opinion. I will take it back in when they can do the work.
11,449
Where / how did you come up with that?
It's a RTV1100CW9 2009-2011
11,449
Here are three sources of the manual:
zfish65
Dec 27, 2022
Fleetwood
RTV1100CWXL-H
You can't trust KPAD with serial numbers as Kubota reuses them. Kubota also doesnt give the year it was built. That machine was sold on 7/15/13. From what Kubota corporate taught me, you go off the warranty date to determine year. If im wrong im wrong but thats what i was taught from kubota themselves
11,449
RTV1100CWXL-H
Yes Kubota does use the same serial numbers over and over, only so many 5 digit combination avalible.
But they do not use the same serial numbers on the same types of units.
In other words a serial number can be the same on a B7100 as it is an L3450 and a RTVX1130
But no 2 RTVx1130 or and an other same model number, will have the same serial number.
Sale date is warranty date
Sale date is not build date
Serial number = build style and date
Build date determines the manuals not the sale date
AgEngr#1
Jan 4, 2023
SE Washington
If you cant find one, send me a message.
I was hoping to find a source to download the manual. I can't find the exact manual on eBay because the manuals there are not listed by part number. None of the manuals show a date of 2012-2013 except there is one listed for the RTV-X1100 which I guess is a newer model that has a different engine/transmission configuration? I run into that problem before when draining the transmission oil and the drain port was located at an entirely different location. Can you assist to steer me to find the proper manual? Thank you.
