RTV X1120D trans issue?
Southpaw
Drummonds,Tn
2014 model with 438 miles. All of sudden it won’t pull up any hill, just sits still and revs up. I was able to put it in reverse and make it back to the barn. I replaced both trans filters and checked the fluid level. It is still doing the same thing. It will get up to speed on a flat road but will not climb under load. Have you any ideas.
whitetiger
Nov 20, 2011
3,715
2,139
Kansas City, KS
Are you checking the fluid level in the transmission or in the hydraulic tank under the passenger seat?
The hydrostat is supplied from the tank and if it is low will produce the exact behavior that you are describing.
