rotary cutter vs. finish mower
rotaryjohn
BX2380, FEL, LPBoxBlade, Piranha Tooth Bar
May 6, 2018
14
Ila, GA
Looking at 4ft. units for my new tractor and trying to decide which is more useful and what capabilities each have. For my current home it will be mostly keeping wooded areas free from briars and vines. some very small saplings from time to time, but will be moving from here in a few years and will go to a larger piece of property. I know the rotary cutter will meet my needs here, but what can a finish mower handle other than grass
esloser
working on BX1870-1
Oct 30, 2015
76
Millville, NJ
I don’t think I’d use a finishing mower on anything but grass and don’t think I’d run over saplings with one. Rotary cutters are designed for the work you want to do.
8,076
For wooded areas, use the rotary cutter.
Finish mower is a lawn mower.
I have both. For the field next door. I used the rotary cutter first. Then went through with the finish mower after to knock it down to where the tenant could mow it with there rider.
Sent from my SM-G920V using Tapatalk
