Retired my 5 gallon fuel cans
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Finally decided to retire my 5 gallon fuel cans. Pricing 50 and 100 gallon tanks, 100 gal. only $50 more but would require a small single axle trailer. Renewed plates on my other trailers and Illinois raised trailer plates by $100. Too frugal to pay over $100 every year for a fuel run.
Farm & Fleet had the 50gal tank and 12v pump on sale, devine intervention?
So the specs of the LA535 are:
Lift to full height (at 500mm): 769 lbs
Water is approx 8#/gal. Estimated 50gal = 400#, extra 100# for tank & pump, extra 200# for lumber. 700# total, My B2650 should be able to lift it (fingers crossed). Drug up all of my extra P.T. lumber and started to build.
The tank is 24x24x24 inches, adjusted forks so tank would sit inside. Seemed wider pallet would be better.
Cut 2 - 4x4's at 33 1/4". Clamped 4x4's to forks using shims for some gap. Set spacing on adjustable square for next step.
Cut 3 - 2x10's at 37", cut 6 - 2x6's at 37". Started with bottom, used square to center 2x10 on 4x4 rails. I used 1/4" x 4" SPAX power lag bolts to attach the bottom boards. Since this is the bottom, I used a fostner bit to countersink the bolt heads. You don't have to pre-drill holes for these screws but, old school me did.
Positioned 1 - 2x6 and 2 more 2x10's, marked center lines
Drilled counter sinks, holes and installed lag bolts.
Flipped unit over and attached 5 - 2x6 boards for top side. I used 1/4 x 5" SPAX screws on the top. These screws do not need to be counter sunk. NOTE: leave gaps where the tank mounting tabs will be located.
Set tank on "pallet" and drilled 1/4" holes in mounting tabs.
Installed rubber tank mounts. Cut 2 - 2x4's at14 1/2" and 2 - 2x6s at 28". Sized some scrap pieces to fabricate a hose box to keep hose off the ground.
Reactions: 6 users
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Don't know the actual weight of this build but the B2650 can handle it
You will want to take a wrench with you on the first fill. This is how much the 50 gals compress the rubber mounts.
Reactions: 9 users
nwjones18
L4701 HST, RCR1872 Rotary Cutter, RTA1266 Tiller and Grapple
Jan 21, 2021
27
38
Warner Robins, GA
I like your setup.. $100 a year for trailer plates is robbery. I think my boat trailer cost me $14ish here in GA.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,744
Kalamazoo, MI
Permanent trailer plates in Michigan. My Load Trail 832414k plate was a smidge over $200.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Nice job and if I used enough fuel each year I would rob your idea.
Been few years back but I got permanent plates for my trailers and it was$75.00 each here in NC.
I head up your way every couple of years to hunt those big ole midwest whitetails. We hunt with a friend near Bushnell who is an outfitter. We were there the 2nd week of November in 2019 and it was the coldest I have ever been. Snow and wind had the real feel temps as much as -14. Bout froze hanging off side of a tree. This ole NC boy likes cold but that was tough hunting for that week.
Have a good day OTT.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
594
343
Mandeville Louisiana
I like it! Is there a bottom drain on the tank? I'd suggest a fused polarized connector mounted on each piece of equipment that requires diesel. the mounted connector could be used as additional 12 source i.e. portable air compressor, lights, etc.
4,311
deleted
Bmyers
May 27, 2019
3,650
4,984
Southern Illinois
That is $100 for the small trailer a year. Our trailer (12K) cost is now $230. If we register it as a farm trailer we get a discount, only $206 a year.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Yes the drain is on the rear of the tank, also using polarized connector with supplied fuse
Tank is another electrical device I can add to tractor
Joe Messmer
ZT21,B3350,LA 534,BT77
Jun 1, 2017
15
Edgewood Ky
Nice Job, trailers in Ky. only require licenses when they are towed by a Co. vehicle with the name on the truck, other than that they are free. About 40 years ago I came up with a 50 gal barrel and have fuel delivered. A few years ago I got a farm permit ( no taxes ) and my fuel man upped the delivery requirement to 100 gal. but it is sure sweet not having to deal with hauling the fuel around.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
The hard part is finished, time to make a "fuel gauge" stick. When full level measures at 21 3/8". What is 1/5 of 21.375? 2/5? 3/5? 4/5? Let's simplify the math, 2 parallel lines 21 14" apart, used tape for this. Place yardstick at an angle to get 25" measurement.
Keep the story stick perpendicular to the 2 lines and mark it at 5,10,15,20 and 25"
Well just seems like it's missing something? ORANGE PAINT easy enough to fix
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
292
92
Southern IL
Did the rubber mounts come with the tank?
Would think having all the weight spread across the base be better than having 4 point loads. Granted only about 100lbs per mount, which those tabs should handle easily.
MDCobraMan
Kubota L3430 Grand Open ROPS, L3430 Grand Cab, F2400
Jun 8, 2021
27
Great job on the fuel system. IAs far as trailer tags go I have all my trailers registered in Main. All legal and so much cheaper. Plus no taxes or inspection fees. Plenty of information on line but here's who I use.
FBJR
2012 L45, 1998 Gehl 5635, 2001 Bobcat 331D
Jun 30, 2020
On the Ridge
Trailers are 5 year in Ca (few things they got right) for about $20.
I got an old 75ga truck tank and hung it off my container (tractor garage). Working on plumbing now
Pepsirich
L3200 w LA524, Bushhog, Rock Rake, 48" Pallet Forks, Auger, 16ft dump, F250
Jun 19, 2021
Buchanan Georgia
Great idea. I also got tired of the cans and bougt a $30 pump and fill it straight from my F250 Diesel tank.
Georgia is only $18 a year 'plate" fee for trailers even through you dont get a new plate. At $100-$200 a trailer I would be getting rid of most of my collection. I have 4 different sizes now.
B737
LX3310
Jun 9, 2019
2,022
2,205
Can you expand on this??? Why would I keep lugging 5 gallon cans when I can pull it out of the truck!
I thought like in gas vehicles there is a blocking baffle to prevent fuel going the wrong direction out the filler neck?
lynnmor
B2601-1
May 3, 2021
1,834
1,631
Red Lion
My 2011 F250 is virtually impossible to siphon, I can only get a 1/4" O.D. hose down in. If there is an easy fix I would like to know.
