Replacing the LCD monitor in a KX41-3v.
oldnslow
L3901, JD2020, KX121-3, Torro 5&7 gang reel mower
Jul 24, 2021
15
Having to replace the LCD monitor in a KX41-3v. I was looking around and on Alibaba they have a listing for a KX36-3, 41-3s, 41-3v, U30-5 and a RX5
Can anyone confirm that these monitor can be swapped between models...
2,495
All I can suggest is to go to Messicks and try to locate the part number. Then you can click on the part number and see the cost. On that screen is a button (at the lower part) that say “show models”. That will list all the models the part will fit onto.
oldnslow
Jul 24, 2021
15
Good info,,, thanks a bunch.
Went to the sight and checked. It was not reflected in the listing.
I never new you could check that way. I sure wont forget..
Im sure Ill use it a lot...
