Replacing a hydraulic control arm on B2650
Jasonc
B2650
Mar 4, 2022
NC
Hello, I rolled my tractor and bent one of the hydraulic lift arms. Has anyone replaced one on a 2650? I can’t seem to find any replacement arms for this particular model or any instructions on how to replace the arm itself? Any suggestions would be appreciated. Thanks!
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
If this is the 3 point lift arms you should be able to straighten them using a hydraulic press. Do you have a picture of the damage?
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
That would be very helpful, Jason. That way we know for sure what you are talking about and the extent and nature of the damage.
I hope nobody was hurt in the rollover! You're able to post here, so that's good, at least!
Jasonc
B2650
Mar 4, 2022
NC
Fortunately I was able to jump off and the tractor just flopped over.
I didn't have a chance to take a pic but the part is the right hydraulic lift arm. The arms that are linked by a splined shaft. I was able to order the part on Messicks and I believe it only involves removing the clip and sliding the damaged arm off and the new one on. Anyone have any experience with this?
11,368
Yep you'll be fine, it's a super easy fix.
whitetiger
Nov 20, 2011
3,811
2,216
Kansas City, KS
There are timing marks that need alined on both the lift arm and the rock shaft when you install it.
