J jpf Member Feb 26, 2016 120 13 18 butler, ga USA Jul 11, 2018 #1 do I have to bleed the cylinders or will they "self bleed"? b-2301
J jnyost New member Sep 12, 2017 27 1 3 Central Ohio Jul 11, 2018 #2 I think my manual states to the run the system back and forth several times to self bleed the system. You could crack the fitting and bleed a little if you want but be careful if one cylinder wants to start moving before the other one.
Kennyd4110 Well-known member Vendor Member Sep 7, 2013 1,426 757 113 Westminster, MD www.boltonhooks.com Jul 11, 2018 #3 Just cycle the controls, no bleeding is necessary or recommended for safety reasons.
J jpf Member Feb 26, 2016 120 13 18 butler, ga USA Jul 11, 2018 #4 thanks guys, that's what I was thinking but thought I would check to make sure. didn't want to make an expensive mistake!
