repair\modify
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
slight problem attaching my bh-77 to the new B2650hsdc
not enough space between back hoe sub frame and the mmm lift pivot.
so i removed the right side tire, mmm pivot rods and the pivot arm.
i cut some of the pivot tubing off from the inside.
finishing that project. i could now bring the backhoe onto a work surface.
to fix some hydraulic manifold leaks. i used a couple of impact sockets, as the mounting pins are hiding...
now if i could only find the mounting pin's..... i think i left them in the b3350... :-(
