Removing the horizontal spring on B2601 HSD
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
148
149
The tractor is 9 days old. I absolutely love it. Except for the reverse pedal. After 3 hours of mowing on it I am now having Achille's tendon pain on my right leg.
For those who have removed the horizontal spring, have you had any issues afterward? I hate to start messing around with a brand new tractor, but something needs to be done to reduce the force needed to use the reverse.
Thanks
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
351
136
St. Louis, mo.
I agree reverse takes a lot of pressure but I’m wondering if removing the spring would cause an issue with going or staying in neutral? If you do it please post the results.
John D 2
Jun 6, 2023
148
149
I may just remove it and replace it with a much weaker spring. There's no sense in it being this difficult.
If I am backing up and pick my foot up to quickly, it shuts it down like I jammed on the brakes.
It's like the reverse pto safety switch that was on my 1025R I traded in. To back up while mowing, you had to push the pto rocker switch before backing up or it would shut the mower down.
John D 2
Jun 6, 2023
148
149
A big thank you to GSD-Keegan for the info.
I removed the horizontal gray spring with drum brake spring tool. (Yes, I'm that old.)
I just drove it around the property. It is MUCH easier to use the reverse now.
When I released the pedal going either forward or reverse it went right back to neutral
lynnmor
B2601-1
May 3, 2021
1,501
1,248
Red Lion
I've had mine off for a considerable amount of time, no issues. I might even replace one of the others with a lighter spring. There is no provision to grease the pedal shaft, so I drilled a small hole near the center of the tube thru to the shaft so I can grease it with a needle point grease gun tip. I cover the hole with a hose clamp to keep dirt and water out.
