Remove rear axle M125X
ChubbyLumpkin
325X
Mar 29, 2013
Nebraska
Trying to replace the left rear axle seal on a M125X tractor and found out that the bearing is out. Looks like you need to remove the axle in order to slide the bearing and seal off.
Does anyone know the trick to sliding the rear axle out?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
169
Hardisty, Alberta
Remove the axle, There is a big (real big!) nut on the inside that you must remove to get the axle out.
eserv
May 27, 2009
2,189
169
Hardisty, Alberta
Yes you do have to remove the axle housing. Not much of a problem except it is quite heavy! Just remove the cab mount and then the ring of bolts and pull it off!
eserv
May 27, 2009
2,189
169
Hardisty, Alberta
I wouldn't want to tackle the job without the proper tools, your experience may vary!
