Remove loader pump shaft from pulley end
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Are you talking about removing the chain coupling?
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
This is a B7100. I want to remove the loader shaft that drives the pump but I cannot see how it is attached to the pully.
It just pulls off. It is a spline connection. It is probably rusted in place.
garyh
Ashland
Really surprising because it moves all around like it was a ball joint. I pulled on it but it must be rusted solid to the spline. Time for liquid wrench and maybe some heat.
bucktail
Jun 13, 2016
1,276
198
MN
It looks like a double chain to me. The 2 sprockets are only held together by the chain. If that's the case, you find the splice in the chain. It will probably have a tiny cotter pin in it. You get the pin our and pull the splice out, the chain comes off and the sprockets come apart. We used this connection on some of our combine heads.
garyh
Ashland
I sprayed it heavily with Liquid wrench and let it sit overnight. It pulled off easily this morning. I did not have to remove any chains etc......Thanks all.
