Remote Hydraulics Kit -$550
TractorInnovations
L3540
Nov 24, 2020
Muskogee, OK
Looking for rear remotes, but don’t want to pay $2k at the dealer? Over 500 satisfied customers have installed this $550 kit – 15 minute install. I use USA-made valves and hoses, and I’m a one-man shop. I build them build them for you, and can customize anything you need!
The kit has a switching valve to divert one of your loader functions to the remote when you pull the knob.
Check out the install video:
www.tractorinnovations.com/kubota
Do you want to run a:
  • Hydraulic Top Link
  • Grapple
  • Implement with a hydraulic cylinder
  • Loader-mounted hydraulic sickle bar mower
  • 3 Point Log Splitter
  • Post Drivers (return line to tank)
  • Backhoe
As a vegetable farmer and Kubota owner, I needed rear remotes but couldn’t justify $2k at the dealer. I came up with this kit which installs on any tractor with a loader, and you don’t even need to drill any holes on most models. It is totally foolproof (you can’t possibly break anything!). The video shows installation on a modern L series, but its compatible with B, LX, M, and MX series, and older tractors as well. We haven’t found a tractor yet that isn’t adaptable to this system. It works on all brands of tractors. Just call or text to hammer out the details.
You can even install two kits to run top/tilt or both functions of an implement from your loader joystick. Flail mowers and snowblowers come to mind.
Tractor Innovations
Andy Herringshaw
DM me or check out my website above for contact info.
