Relocate a Concrete Slab
memtb
Kubota M6040
Jun 6, 2017
34
45
Winchester, Wyoming
A bit of a challenge, that went better than expected.....relocate a 8’x10’ concrete slab. We live quite rural, and burn our trash....then separating metal and glass/ash,etc. Our “burn barrel” and trash barrels were on the aforementioned concrete pad.
We recently put a swimming pool in the back yard, and were concerned about the burn barrel being upwind (generally) of the pool. Meaning.....move the pad!
First step was add a bunch of sand (removed from the back of our place) to the new location. Then lift the slab with the bucket (one corner at a time), and block with a 10” post. Placed a large “choker” around the end of slab. Secured the “choker” to tractor lift arms with chain, lifted the end of slab, and drug it about 150’ to new location. Square the slab with the tractor bucket, lifted the slab and pushed sand under slab with a garden rake in the low areas to make slab level. Used the rake to drag the excess sand around the slab and grading from ground to slab! Knocked it out in about 3 hours.....Love my Kubota! memtb
7,167
I've got to say it..... No pictures means it didn't happen!
Seriously, even without pictures sounds like a greatly executed plan!
Good for you.
SidecarFlip
Banned
563
Picked up my neighbor's pickup truck once with one of my M9's.
4,682
With my luck,, it would have crumbled in to a dozen unusable pieces,,, ya done good
memtb
Kubota M6040
Jun 6, 2017
34
45
Winchester, Wyoming
Good for you.
RCW.....Here ya go! And it wasn’t perfectly executed, when moving it around to “square it up”.....I broke a small piece off of the corner! :mad: Can be seen in last photo ( front right of slab). memtb
7,167
Wow - - excellent to move that with just a small corner broken!!
Like skeets - - I'd a had it in a bunch of little pieces. :rolleyes:
Benhameen
Jan 27, 2013
713
135
Southern IL.
Nice! I did something similar a few months ago but mine was only 36”x36”.
I took out a sidewalk in the back yard to extend the concrete patio a few months ago. We needed something to sit the trash can on. I’m so I recycled a piece of it. Cut it up into pieces that would fit into my bucket. Works like a charm.
