Rear Wheel bolts -Removal
Thorny
L2501 HST, 4x4, FEL, front snow blade, rotary cutter, box blade
Sep 24, 2016
90
Mountains of CO
I was going over my L2501 greasing and torquing bolts today and when I got to the rear wheels I didn't have enough wrench extensions to get my torque wrench in to the bolts and have the wrench outside the tire. I'm just curious how you guys do this? Really long extensions? Or is there a simpler way to do this job? With a 160 ft-lb spec, I need a long bar to tighten that bolt
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,058
Williamstown Ontario Canada
Get a cheap but amazingly powerful torque multiplier.
Until you see one in action it is hard to believe.
Ebay $75
http://www.ebay.com/itm/HOMCOM-7pc-...363749?hash=item5669b085e5:g:4C8AAOSwjVVVusdQ
Youtube videos
https://www.youtube.com/watch?v=vesBDXCWrUw
There are many different style so you need to educate yourself and select one which will do other jobs for you like get the nut off a bush hog.
The torques they generate on some models can exceed 2000 ft lb yes Two Thousand ft lbs.
Mechanics working on Bulldozers out in the mud use them Truckers who change their own tires use them. You cannot have your 1" impact gun and air compressor with you but the torque multiplier comes in a neat case.
Dave M7040
