Rear remotes
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
67
Minnesota
I looking to add a 3 spool hydraulic valve (tandom center) for rear remotes on my Kubota L3901.
The valves I see have a relief valve on them.
I am wondering if this is needed as I would add this valve to the power beyond port of the open center system which is regulated pressure.
If I understand right there should be constant flow through this manual valve.
Thank you
5,947
Thank you
You dont need a relief valve but it wont hurt anything.
You do need a valve with both tank and power beyond ports.
OldcrowP51
Aug 18, 2021
67
Minnesota
Are you saying there will be one infeed line to the valve and two discharge lines?
