The backhoe does not use a rear remote. It has it's own wet lines that the dealer will install. While there in there you may as well get them to put a remote on for future use.....it's going to be running to the same place.Planning on purchasing a BH92 for my mx5400. Do I need a rear remote? Dealer advised that I did not need a rear remote and said that the hoses connect under the tractor to get fluid to the backhoe.
I agree wholeheartedly. I bought my tractor with a backhoe and it could have been plumbed for remotes at the same time when the backhoe lines were installed, but the dealer talked me out of rear remotes. While I have not had use of remotes so far, I wished I had made them install the remotes. I am really not sure why he was so against installing remotes when I asked for them.The backhoe does not use a rear remote. It has it's own wet lines that the dealer will install. While there in there you may as well get them to put a remote on for future use.....it's going to be running to the same place.
My dealer was against doing the rear remotes as well. That’s why I was asking. Wonder why that is?I agree wholeheartedly. I bought my tractor with a backhoe and it could have been plumbed for remotes at the same time when the backhoe lines were installed, but the dealer talked me out of rear remotes. While I have not had use of remotes so far, I wished I had made them install the remotes. I am really not sure why he was so against installing remotes when I asked for them.
I have no idea why they would be against that.......it's not only more money for them to sell it but they are literally already disassembling to the point to install them, or it's not even a disassembly if your tractor isn't built and coming out of a crate. All you need is the right rear wheel off. Everything is so much easier when it's clean and rust free.My dealer was against doing the rear remotes as well. That’s why I was asking. Wonder why that is?
Always. On a (compact/subcompact) utility this should basically be standard.FYI: Consider a 3rd Function for the front too.
I already got the third function for loader. Just waiting for backhoe to come in.FYI: Consider a 3rd Function for the front too.
Nice!I already got the third function for loader. Just waiting for backhoe to come in.
