I have installed this 3 spool valve after the loader spool and before the rear 3 point control.
https://www.surpluscenter.com/Brands/Prince-Mfg/3-Spool-8-GPM-Prince-MB31BBB5C1-DA-Valve-9-7863.axd
I made sure it's in power beyond configuration, I do have 3 point control so it should be correct.
The problem I have is I cannot control rear cylinders. It bogs does and clearly is going across the wolverine pressure relief valve. If I put dummy quick connects in any of the 3 paired rear remote lines and activate the corresponding spools, I get fluid on BOTH working ports! How can that be??
Sent from my SM-G955U using Tapatalk
