Rear blade
kcs
Kubota B2650
Jan 9, 2021
148
I’ve got a 72” rear blade for my B2650. It has a steel cutting edge. IF we get any snow I’ll be cleaning driveways and my church parking lot. Would the steel edge hurt the asphalt or should I look for a rubber edge ………. Thanks
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,431
1,718
Kalamazoo, MI
I would invest in a rubber or UHMW cutting edge. Asphalt is easily damaged. Check Good Works Tractors. They ship anywhere.
5,695
ummmmm..
have you ever looked at blades on snowplow trucks , or JEEPs that snowplow....?? :oops:
the one thing you should consider is changing the blades angle so the top edge is slightly forward of the bottom edge.
5,175
If the asphalt/concrete is flat and smooth.....Just plow it!
Don't over think it!
Daferris
LX2610
Nov 23, 2021
480
402
Mid-Michigan
I have a 250' asphalt drive that I plow with a steel edge back blade. Agree the trick is to shorten the top link so the blade is leaning forward ( assuming you plow like I do driving Forward) if the snow is more than about 8" I will set the bucket about 4" off the drive to Cut the top layer off. Much easier and faster than plowing backwards.
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,121
825
Wellsville, PA
A steel edge will always mark up asphalt to some degree if the asphalt is in poor condition it will be even worse.
kcs
Kubota B2650
Jan 9, 2021
148
Awesome thanks for all
The info I think I may order a UHMW from
Good Work Tractor. I’ve seen some YouTube videos and they look pretty good
5,289
I have used a steel blade on my asphalt for decades with no issues.
ken erickson
Nov 21, 2010
1,256
2,165
Waupaca Wisconsin
I use a King Kutter 6 foot back blade on my blacktop driveway with no damage. I will say that the cutting edge has worn down to about 1/2 wide contact area. Works perfect in my opinion. If I ever use the blade for serious dirt work I would probably reverse the cutting edge and restore to factory new.
Bearcatrp
Mar 28, 2023
870
512
Minnesota
Just to add to the conversation, I brought in class 2 for my dirt driveway. Tried using the back blade to smooth it out but it kept digging in. I spun the blade around. Worked fairly well smoothing it out.
5,175
Successful "grading" with a rear blade requires much experience.
Though I do not have one, I suspect that a land plane is a MUCH easier tool to use!
jyoutz
Jan 14, 2019
3,382
2,423
Edgewood, New Mexico
Or for much cheaper, just unbolt the steel cutting edge and bolt a piece of plastic board like trex in its place.
jyoutz
Jan 14, 2019
3,382
2,423
That’s the trick for smoothing with a blade, and it also works well for snow removal on a gravel road without disturbing the gravel.
Bearcatrp
Mar 28, 2023
870
512
Minnesota
Haven’t tried
Have not tried it in the winter yet. Am hoping the snow pusher I bought works with out removing to much gravel in my driveway. Until it freezes hard, I suspect I’ll be taking some off the top. Was thinking of removing the blade and trim 1/4 inch off the snow pusher blade.
jyoutz
Jan 14, 2019
3,382
2,423
Haven’t tried
Just turn the blade around backwards and float it on the 3ph. It works great.
