Rear blade weights
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
6' rear blade with old cutting edges for weight, hung from S hooks. Where would you hang them? Edges/ends or middle? I usually have them on each end of the blade but want to try concentrating the weights in the middle.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,555
2,013
Western MT
I would put the weights on the frame/structure that attaches to the 3 pt. Otherwise, they will be a pain when you adjust the blade. I also think the performance would be more consistent added to the frame/structure.
5,660
Can you adjust the tilt of the blade ? My ancient blade does this and it made a world of difference for grading the driveway. OK, it took me 3 hours of heat,oil and 'perswaysion',but it's now EASY to adjust 'just right'....
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,559
1,797
Near Lancaster, PA, USA
My rear blade usage over the years has been mostly for snow. In that application, weight wasn't an issue. I tried doing some grading a few times and didn't have much success. Some posters mention that it worked for them, but with blades much heavier than any I've had.
When I did have some serious grading to do I bought a used box blade with scarifiers for the project and resold it when done.
Dave Ogren
BX23S w/FEL &BH &60" Mowing Deck, 48" Dirty Dog Box Blade, 48" Tar River Tiller,
Feb 16, 2022
100
47
Asheville, N. C.
I adjust the tilt of the blade with the top link. Have not needed weights.
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
Most of my usage is snow removal, I reverse the blade so that it does not cut. My question was about weight distribution, center or edges. I can tilt the blade but it is too much angle for what I do.
