Rear Blade/Landscape Rake
Porcupine
L2501
Jun 15, 2021
125
153
NC
One of the tasks I use my tractor for is cleaning out the barn.
For now it’s got a dirt floor. We put shavings down, and goats being what they are, spent hay gets mixed in too.
Add copious amounts of urine and berries, and the result is a mix of matted wet hay and shavings and…”stuff”.
I generally start on one side and scrape the material to the middle with the rear blade then come around to scoop the material with the front loader. I’ll then do the other side, and repeat as necessary.
My main question is: Would a landscape rake be a better tool? The RB does well, but it can be hard on the floor. I’m not looking to scrape dirt out, just remove the material on top of it.
One of my next projects is to grade the floor and add material (gravel, sand, and grit, so I’ll still want to be easy on the floor even after I improve it.
Other recommendations are welcome too if one feels the question is too narrow.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Maybe replace cutting edge with rubber strip. A rake with springy tines will fling undesirable material all over you.
Porcupine
L2501
Jun 15, 2021
125
153
NC
One man’s trash is another man’s treasure
Funny thing-I compost it and I’ve got a guy who buys all of it we produce when it’s about half done.
I’ve sold many things over the years, but I did think to myself after the first transaction: “Well-that is the first time I’ve literally sold someone a giant pile of crap.” :)
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I have raked a ton of paddocs and barn isles over the years I do not recall a single time that I got hit with "stuff". My 6' rake is about 6' behind me.
Porcupine
L2501
Jun 15, 2021
125
153
NC
Does it work well for matted hay?
I was also contemplating a toothed bucket edge as sometimes the mats stick together and get pulled back out of the bucket when lifting.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
I also have a similar situation with my floor but no problems I put 1/2sure pack down 8inches worth in 2 lifts packing with 800lb plate compactor it's justlike concrete. I also was tired of on off tractor and handling the matted crap lol had a local fabrication guy build me a manure fork for tractor chains on bucket in seconds to put on or off. Turned hours of labor in to minutes.
Porcupine
L2501
Jun 15, 2021
125
153
NC
Hmmm,
I know those are all English words, but when you put them together in that particular order, I’m not sure I understand completely. ;)
Is Sure pack a type of gravel/aggregate?
What’s the fork look like? I’m intrigued.
One of the deficiencies of our barn design is a lack of places to push a bucket against. I havn’t decided how I’m going to fix that yet.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,908
2,320
Western MT
I would use a rake. To me it’s like using a regular rake instead of a shovel.
6,873
Is there any reason why you couldn't use the backside of your rear blade? either spin the blade 180 degrees, or push the blade in reverse. Doing so should still move your "muck" but not dig into the dirt.
I use the same method for plowing snow on a stone/millings driveway.
Ikc1990
Dec 2, 2020
292
130
Vermont
Hmmm,
Sure pac, staymatt, plant mix is all same material it is only found at rock quarry with crusher. Sand with round rocks junk. Even sandy gravel run throhcrusher isn't great it better buf 100% crushed rock is way to go. It packs the stuff with round rocks dosnt stay tight. You cant compact marbles. But you can the crushed rock esp when moist when dries up it hardens un like sandy soil it drys out becomes looser again.its the sure pac when dry and wet and compacted properly is like pouring concrete. But much cheaper
Porcupine
L2501
Jun 15, 2021
125
153
NC
I’ll
I’ll give that a try. The way the barn is laid out, it’s best to pull everything to the center. I still need to find the balance between digging into the mats, and not digging into the floor.
I’m sure much of the solution depends on developing more skill with the rest blade.
The challenges I’m having aren’t huge issues. It’s more seeking better efficiency/reducing required time for a task.
Porcupine
L2501
Jun 15, 2021
125
153
NC
Got it!
Sounds like what they call “Crush and Run” here.
Ikc1990
Dec 2, 2020
292
130
Vermont
Got it!
Check with them cause round here is bank run Gravel put through a crusher hence crush and run. That's only a partially crushed product that's normally more sandy.
