Re-Attaching BH77 on aB3030 problem.
shirleyujest
b3030, rc72-30b, bh77, la403
Nov 11, 2016
shirley, in
Having problem re-attaching BH77 to my (new to me) B3030.
The L Shaped bracket that pulls on linkage for RC72-30B mower interferes with the Bottom Right (direction of travel) lower pin of the BH77 when attaching backhoe.
This bracket is the one that sits on top of lower right lift arm, and stays on tractor after lift arms are removed.
Unless the rod with clevis on both ends is removed the L bracket is trapped between Backhoe and backhoe sub-frame. The rod cannot be locked up with the holding pins after mower is removed.
Have replaced L shaped bracket. Dealer has called Kubota, and this is the only unit having this problem.
Need help. This is a PITA.
