Quick Hitch
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I bought a quick hitch last week and I know it will not work good on some of my attachments. I would like to know the length on the add on part for the top length that you have to add so you can hook up the older tools. Can anyone help?
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
I don't think there is a standard for all quick hitches and certainly not a standard for old non-quick hitch implements. So even if you supplied the brand of quick hitch and all the implements you plan to use it with, the best answer would be you will have to hook each up implement and determine what modifications or adapters you will need.:(
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
there's no really stock answer to that ,sometimes its only a 1/4" sometimes a lot more. Your going to have to try each of your impements and make modifications to the implement or top hook as needed. I gave up on the quickhitch on my B2620 and went with pats adaptors for lift arm ends.
bandaidmd
May 19, 2013
603
Middle of DELMARVA
Both of us Larry's typing the same reply at the same time.
bcp
BX2360
Apr 20, 2011
644
79
SW WA
Just make one with several holes. Here's mine.
Yes, when I put it on for the photo, one side was reversed and I didn't notice.:)
Bruce
