Quick Attach for 3PH??
Mike.O
B2650
Mar 28, 2017
109
CT
I have a set of quick attach pallet forks. I made up some +/- 1/3 cord boxes to haul firewood from the back woods to the house. My concern is the B2650 won't lift these. Anyone know of a company selling a SSQA for the 3ph so I can mount my pallet forks to the rear. I have about 6-800 more LB of lift at the 3ph.
This is what I'm after, but holy cow, why the absurd price?
http://www.everythingattachments.co...iversal-Quick-Attach-Adapter-p/ati-qa-3pt.htm
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
If you have good skids, you can pick up a carry all frame for less than $150. The only problem I had was the old skids warped and didn't have enough room for the angle irons to fit.
Sent from my LGMS330 using Tapatalk
Mike.O
B2650
Mar 28, 2017
109
CT
It's not easy to find on their website but Titan makes one:
https://www.palletforks.com/tractor-attachments-198/tractor-attachments/quick-tach-adapters/3-point-to-universal-quick-attach-adapter-skid-steer-tractor.html
I thought I had looked all through their site but I had no idea that had that until someone else linked to it on a forum.
Awesome! Thanks! That is definitely a little more in the price point I was expecting and exactly what I'm looking for. Do you have one? is it sturdy? You think it will allow me to maximize the 3ph lift of my B2650, approximately 1600 LBS.
And yes the boxes now are sturdy, made of left over 2x4's and scrap plywood. I will also look into the carry all option. I just made these and havn't loaded them up yet, so maybe the front end loader will lift them (I doubt it), but once I confirm it can't (or hopefully can), I will look into purchasing something for the 3ph.
2,467
For the rear they sell carry-all for light weight lifting and pallet forks for heavier loads. Be sure to check out the capacity of the implement before you purchase.
Mike.O
B2650
Mar 28, 2017
109
CT
Well the goal would be to utilize the SSQA palled forks I already have, so I think the best option would be the 3ph SSQA adapter, as long as it has enough capacity. I cannot seem to find a capacity on the Titan website.
eipo
L4060
Dec 1, 2015
699
85
MI
I don't think the 2650 will pick that up using the front loader if it's full. I use tote frames with the top rung cut off and filled with loose, green wood it's about all the tractor wants. Seasoned wood with some ballast you may be ok, but I don't think so.
I'm also looking to utilize the 3 point to move totes. Move twice as much wood in 1 trip.
Sent from a field
eipo
L4060
Dec 1, 2015
699
85
MI
This is a load of ash that's been on the ground for several years. Tractor didn't have any issues but I knew it was there. Moisture in this was averaging 18%.
These are standard size pallets with welded wire fence to make the cage and green wood thrown in. Some of these I had to lighten up in order to move. But as they sit in the picture the tractor had no problems but again, I knew they were there.
Sent from a field
origami
'12 BX25. Previous: '95 B1700
Apr 18, 2016
62
Leesburg, VA
Sent from a field
Great idea using the tote frames. Very clean.
Sent from my SM-T713 using Tapatalk
eipo
L4060
Dec 1, 2015
699
85
MI
Something to think about. For about the same money you can get the pallet forks and have them on the front and back.
Sent from a field
eipo
L4060
Dec 1, 2015
699
85
MI
Thanks. I don't use them to season, just to toss into off the splitter and transport to the stacking area.
Sent from a field
scdeerslayer
MX5200DT
May 23, 2016
434
SC
These are the boxes. View attachment 30216
No I don't have one, but I couldn't imagine that it would be a problem on your B. You will have a bit of a penalty on that 1600 lbs though, since you basically have to subtract the weight of the device, and subtract for the extra length that this will push back the load.
Mike.O
B2650
Mar 28, 2017
109
CT
Sent from a field
Thanks for the reply eipo! Those totes are what started this whole firewood moving venture. Usually just use my truck, but this has to be easier. I can fit 2 under my sunroom which will be sheltered and is right by the door where my stove is. I wanted those cage totes but around here people want 75-125 a tote, which is nuts. I've got my eyes out for a deal on some, but for now this is the route I'm taking.
My wood is all red oak and sugar maple so my density is quite high.
Once I get a feel for how it does on the front forks, I'll reassess and see about acquiring a 3ph SSQA adapter or maybe used 3ph pallet forsk. Maybe I will be content filling the boxes less or use smaller boxes. Should be a learning adventure this wood burning season.
