PTO RPM vs Engine RPM
belah
M 4030 SU Tractor
Dec 8, 2010
9
Jena,Louisiana,USA
I have a 1993 Kubota M4030su 2 wheel drive with a 540 PTO. What "ENGINE RPM" do I need to run the PTO at 540?? I will be operating a 25 kW Winco PTO Generator which calls for 540 PTO RPM. Thanks Belah
TGReaper
BX2200
Sep 28, 2010
10
I stand to be corrected,but it is my understanding that the 540 R.P.M. is the maximum PTO speed at maximum governed engine speed.
Mingy
L3010 backhoe FEL, B2300, M9000
Jul 27, 2010
Ontario
On all my machines, if I recall correctly, just a bit over 2000 RPM gives you 540 RPM. My engine RPM goes well above that and I have often run the tractor at higher RPM. For some attachments (like my backhoe, which has a PTO driven pump) I run the PTO pump well above 540.
L4740
222
3rd Rock From The Sun
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
belah, That is correct. I checked my Dad's '93 M4030 SU (this past weekend) that he bought new and 540 pto rpm shows to happen at 2200 engine rpm. Good Luck!
