PTO not turning, what would you suspect?
littlecmonkey
15
By the Great Lakes
First time tractor owner here...less than 50 hrs on a L3540 HST.
Today I decided to blow some light snow off the drive. Less than 50 yards into the game the PTO quit turning my Erskine pull behind snow blower. Didn't hit anything; snow was light and less than two inches.
When I now engage PTO tractor motor seems a bit more labored, and safety switch still turns tractor off if PTO is engaged.
Always happens on a Sunday, when everything is closed...
Any ideas?
11,368
Is it a PTO problem, Or a Implement problem.
Did you disconnect the snowblower PTO shaft and check for free movement of the blower?
With the snowblower shaft removed from the tractor's PTO check and see if you get the same bog down engaging it.
If you do then something is wrong with the tractor, if it doesn't then the problem in the snow blower or the shaft is binding.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Don't know that tractor, but assume it has a clutch for pto (also). In this cold weather could water have frozen on the pedal linkage or a shaft and you don't have the clutch itself fully engaged? Did it come out from a warmer storage place, like a garage? Warm up things and see if it goes OK there?
11,368
The PTO clutch on that model is a wet clutch type, and it also has one odd add on, it has a disk brake on it (stops the PTO from free spinning).
It could be a simple adjustment to get the brake to release when the PTO is engaged, The problem is your not going to be able to do the adjustment, it's all hydraulic and possibly internal.
littlecmonkey
15
By the Great Lakes
It ended up being an implement problem. I went out to attempt to disengage the shaft, and noted two small triangular parts that originally were lined up with each other were not so now. Sheared a bolt is all. Got it replaced and all is well. Hadn't hit anything though...maybe the cold? I'll have to stock up on a few bolts as spares.
11,368
Excellent, once you get done dealing with your snow come on over and deal with mine too please! :D
I'm just heading out now to see how bad it's gotten out and about. :eek:
RBA50
B2320, LA304 loader (B1658 QA), B2789 snowblower, RCK54-29B MMM, HF quick hitch
Apr 29, 2013
133
20
Goldendale, WA
Make sure you are engaging the PTO at idle. The shock of engaging at higher speeds can shear a bolt.
