That's what I used on mine last year, cleaner and coolant. So far, so good.I've read my manual and I'm still unclear. This should be the stuff. Correct?
My manual also suggest a cleaning. I know it's over due. Prestone flusher as well? Any watch outs if I follow the manual? Thanks.
View attachment 83867 View attachment 83866
Hello LaryBud,
When I last looked into it, Kubota anti-freeze was actually "CCI" anti-freeze. I took a quick look at the specs and it looks like the Prestone will do the job, but satisfy yourself, and take some time to look over the MDS sheet on the product, and make up your own mind. It is interesting to note that the MDS sheet describes the product as being clear with a coloring agent added. So much for selecting anti-freeze by color!
Good luck to you!
Cavitation is only an issue with wet liner diesel engines.That's what I used on mine last year, cleaner and coolant. So far, so good.
That's what I interpreted my manual to be saying, "fresh clean water with antifreeze". LOL
Our Ford 3930 (1993ish) says to use an additive to avoid cavitation damage to the cylinders. I think cavitation is a bigger problem with direct injection, so Kubota doesn't see the need since their engines are mostly IDI.
Coolant has changed a lot over the last 20 years or so, complicating the issue. Fleetguard has a whole line of diesel coolants, additives, and test strips for diesel engines. I may look into it sometime, especially for the Ford, since the additive depletes and I'm not sure when and how much to add.
Sorry to side-track your thread, but I'm sure it's bound to happen. We need some good 'best oil' banter on coolant.![]()
Ive read that other places, but the 3930 has dry liners. Maybe a Ford/New Holland standard, since their big tractors run wet liners? I don't see why wet/dry would matter.Cavitation is only an issue with wet liner diesel engines.
It matters because cavitation occurs on the coolant side of the liners where cimbustion temps are high and it erodes them. That is not an issue with cast blocks/dry liners.Ive read that other places, but the 3930 has dry liners. Maybe a Ford/New Holland standard, since their big tractors run wet liners? I don't see why wet/dry would matter.
Seems like the coolant side of a cast iron parent bore cylinder would see the same conditions as the coolant side of an iron wet liner to me.It matters because cavitation occurs on the coolant side of the liners where cimbustion temps are high and it erodes them. That is not an issue with cast blocks/dry liners.
I am not an expert on the matter and all I can tell you is what I have read about the phenomenon. The physics of wet liners is different. This is one of many articles on why the problem is only an issue with wet liners. You can easily find many more.Seems like the coolant side of a cast iron parent bore cylinder would see the same conditions as the coolant side of an iron wet liner to me.
