power steering success on old kubota
kubotaman
l295 dt
Jan 16, 2011
34
pelion sc
finally a succesful conclusion to adding power steering to my l295dt . many thanks to this forum and the videos from service dept vic . this addition while a tad pricey is well worth the expense and effort. feel like i am driving a different tractor . anyone out there thinking of pursuing this addition to their tractor , be aware of the following.
1 - be prepared to spend 800 to 1000 bucks depending on how much you can do yourself or howw cheaply you can find someone willing to do it . the local kubota dealership looked at me like i had 3 heads when i told them what i planned .
2 - make sure you have all the instructions and imformation before you start
3 - the cylinder can not be tied in with anything else . it must have its own supply and return . i initially tied mine into my loader and when i turned the steering wheel the loader went up and down and when i toggled the loader the steering cylinder activated . thanks to service dept vic i was able to cut the high pressure line and move my loader sypply lines . make sure if you call a supply house about fittings for this line to let them know its metric .
4 - if you are dealing with an older tractor be prepared for the inevitable of something else causing problems ( busted loader lines , broken fittings ect )
all in all as i said before it is well worth the time and expense even if i did consider taking a match to it in the process lol . i would be happy to share any pics or tips to any yhat need it
Kytim
Aug 14, 2009
848
15
Western Ky
I agree with Vic! It would be nice if folks would take a few pics, or bunch even, and relate their results. Those actions would help build the knowledge base for all of us. You know, kinda like a Kubota history book of projects!
Kytim
fbson395
L245DT
Feb 6, 2011
12
Tehachapi Ca.
Kubotaman, Glad to hear you got power steering installed. I plan on installing it on my L245DT. For anyone who wants to install, try this site.
http://www.tractorpowersteering.com/
Ask for rick, he has a kit and it's price is about $500+ . He has been out of stock on some of the parts and I'm waiting for a call from him to order the parts for my unit.:(
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
http://www.tractorpoersteering.com/
Link dead!!
Dave
kubotaman
l295 dt
Jan 16, 2011
34
pelion sc
vic , i moved my loader lines and tapped in to the high pressure line per your video . after i did this i noticed the loader seemed to have more power but also was more of a drain on horse power when in operation .also the toggles for the loader wanted to stick in the wide open position when operating and cause the motor to bog down to the point of shutting off . today as i was moving some dirt the hydraulics stopped working altogether . neither the loader or the 3 point will respond . if i try to raise the bucket it drops lower . they will hold their position and dont leak down but will not go up . i unhooked a steering line to see if fluid was coming through . it was but looked like water coming out of a water hose , there seemed to be no pressure . i removed the rear cover on the suction screen and to my surprise there was no screen inside . there is a filter on the right side of my tractor that you get to by removing the bottom plate , this filter looked relatively clean but i cleaned it and put it back anyway . the fluid that i drained was really brown looking . have i got a bad pump and do i need to put that rear suction screen in since i have the one in the front ?
