Poor man mulch kit
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
Added a plate to the deck discharge more so to reduce the width by a foot than the mulching effect. Couldn’t believe how much debris was packed under the belt covers around the belts and gearbox as the mower only has 38 hours on it. Needless to say, the belt covers will not be going back on.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,441
1,735
Kalamazoo, MI
Belt guards are the first thing to go on any of my mower decks. When you let clippings build up, they hold moisture and rot out the spindle mount areas. Second thing to go is any and all operator presence devices. Third things are the anti-spinny chains on PTO guards. Bring on the flames!
lynnmor
B2601-1
May 3, 2021
1,688
1,479
Red Lion
In the fall I get leaves jammed around the deck pulleys so I took off the guards. While mowing along a fence line at a tilt, I put my foot down to help with my balance, right on top of that spinning pulley. It cut right up thru my shoe and into my foot so off to the emergency room. The next thing I did to the tractor was put the guards back on. That was about 20 years ago and my foot still has some numbness but I learned my lesson.
Ton
BX2380
Aug 26, 2022
58
116
MD
I just remove the guards and blow spindles off with compressed air after every few uses or after one hard use. Then reinstall. Also a great opportunity to give those spindels a shot or two of grease. Only takes 2 minutes, or about one-quarter-of-a-beer worth of time after mowing ;)
dlsmith
BX2230, LA211
Nov 15, 2018
1,311
947
Goshen, IN
I pull the covers on the deck on my BX and blow out the clippings with compressed air after every mowing session. Can't believe how packed with clippings they get after a couple of hours of mowing.
Mowbizz
Bx25d
Aug 19, 2021
567
328
On a $9,000 piece of equipment (new Z422) the whole mower gets blown off with my leaf blower after each use, then rinsed of dust and sand, then blow dried. This is my method of keeping a nice machine for many years! 😊 as it goes back in the shed, it looks like it’s on a showroom floor.
