Planter size for 30hp Kubota
sodak
53
Sioux Falls
How big of a planter do you think a 30hp Kubota could handle? There is a 4 row one on the local craigslist, but I have no idea if that would be too big for my B3030...
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Conventional till, flat ground, maybe, on a good day with a FWD, but no till, no way, too heavy. I have seen dealers cut up old planters into single or double row units, that a 30 HP would pull...:D:D
stkline81
10
US
I've got a L3010 I'm going will pull a two row planter with. The ground is already disked.
Sent from my SM-N920V using Tapatalk
HighSierra79
B7100d, M6800 w/FEL, 7' mower, 7' box blade, 42" LP tiller, 5' rake
Sep 1, 2013
74
MO
What type of four row, an old IH, deere? A four row before the 7000 Deere series, I would assume would pull fine behind 30hp w/fwd. Considering your not planting super deep, and the ground is worked. But, my question is, how much ground are you covering with a 4 row. I could plant a lot of ground with a 4 row in a day. I would want something larger, tractor wise, if I was gonna lug a 4 row over 20+ acres with that tractor, considering not wanting to run continous in FWD.
